DIY Valve Adjustment
Old Apr 16, 2013 | 06:06 AM
  #101
tama05's Avatar
So once #2 cylinder is adjusted and still at TDC, then you can put the valve cover on. Wasn't sure if another cylinder had to be set to TDC before putting everything back together, just curious, thanks.
Old Apr 16, 2013 | 11:08 AM
  #102
dwight's Avatar
Crank position doesn't matter for replacing the valve cover.
Old Apr 16, 2013 | 07:09 PM
  #103
tama05's Avatar
Ok thanks, just wanted to make sure that's all.
Old Jan 23, 2014 | 07:49 PM
  #104
almawa's Avatar
So I guess for our engines you don't need to use hondabond sealer like on K series engines?
Also, are the clearance specs different for F20 and F22?
Old Jan 24, 2014 | 03:38 AM
  #105
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
A touch of Hondabond is used in the cam hump corners of the K motors as it is a vulnerable spot to leak.
the S2000 doesn't need any because it is completely flat (no cam humps)
F20C and F22C have the same valve specs.
.011 exhaust valve clearance is recommend for at LEAST 06-09 USA cars.
Old May 30, 2014 | 12:19 PM
  #106
jWESTFOO's Avatar
wouldn't you need to remove the spark plugs to crank the engine clockwise?
Old May 30, 2014 | 01:05 PM
  #107
Slowcrash_101's Avatar
Nope just disconnect the battery so you don't accidentally crank the car lol.
Old Feb 10, 2015 | 01:09 PM
  #108
darcyw's Avatar
Interesting note- are we thinking even non DBW should be at the .011" exhaust spec vs. the .010 as previously recommended?
darcy
Old Feb 10, 2015 | 01:41 PM
  #109
zeroptzero's Avatar
The engine turns over much easier without the plugs. I like to pull the plugs so I can read them, and it makes the valve adjustment easier.
Old Feb 10, 2015 | 02:26 PM
  #110
Of course you're correct, it does make it a lot easier to not fight the engine compression, but if you're manly enough and have the right tools it's not necessary. That said, I remove the spark plugs as well(to replace them), along with replacing all the spark plug tube seals and valve cover gasket every time I do a valve adjustment, just for peace of mind.
