DIY Valve Adjustment
Old Apr 21, 2006 | 05:37 AM
  #31
nibble's Avatar
have you done it before? if not, you must do it.
Old Jun 2, 2006 | 09:21 AM
  #32
1AP12NV's Avatar
To make the "tool" to hold the nut you can also take a regular old wrench, heat it, and bend it at the right angle. Nice writeup!
Old Jun 8, 2006 | 04:05 AM
  #33
silencertk's Avatar
what's the general opinion on having HONDA do it? I'm debating. I don't really have the technical skillz to try and atempt it, and the dealership says it's not that expensive.
But i've heard that you should only have a trusted mechanic do it, because other's may be "sloppy"...
Old Jan 30, 2007 | 10:04 PM
  #34
SilvCF2k's Avatar
Isn't the firing order wrong? 1-3-4-2 Why are you adjusting it different order than the firing order?
Old Mar 14, 2007 | 08:30 AM
  #35
tinkfist's Avatar
Can we get an edit on the OP?
Old Jun 8, 2007 | 12:54 AM
  #36
LegendaryHarry's Avatar
old i know. but how often should you do a valve adjustment
Old Jul 2, 2007 | 07:45 AM
  #37
robodeath's Avatar
would a short stubby wrench work?
Old Aug 14, 2007 | 12:24 PM
  #38
hornyhonda's Avatar
Do honda recommend the valves are adjusted at 100/110k miles? I know its good practise to check but is this the recommendation
Old May 14, 2008 | 09:23 PM
  #39
s2kattack's Avatar
good thing you used a ratchet and not a breaker bar like i do to turn the crank pulley.
Old May 14, 2008 | 09:28 PM
  #40
s2kattack's Avatar
it also says to turn the crank pulley counterclockwise.
you should turn it clockwise to keep the correct firing order. our engines turn clockwise.
some people might want to turn counter-clockwise to make it easier to turn(no compression), but if you do this, you will have to go backwards(1-2-4-3)
or you can just take out your spark plugs and go clockwise to make it easier
