Does the intake cone brand/type matter?
Old Feb 8, 2019 | 08:23 AM
  #21
s2000Junky's Avatar
Originally Posted by rrounds
Only way to know is to put a air filter restriction gauge on your intake. I put one on my '06 and went 90k miles on a Wix air filter without any restriction.
https://www.s2ki.com/forums/s2000-un...ilter-1163927/
If the stock air filter puts no restriction(as shown by a air filter restriction gauge) how can a filter that flows more cfm make more power?
If the engine is getting 100% of the air it wants at WOT with no restriction, putting a larger filter on it won' t get you more hp.
If someone on here can show me how a filter that causes no restriction cost the engine hp I'd like to hear your theory on that.
ROD
Correct, assuming no vac seen at 100% WOT at redline/max cfm. The only other reason for a larger filter beyond that is longer change intervals before vac/restriction is eventually seen.
Old Feb 8, 2019 | 08:27 AM
  #22
s2000Junky's Avatar
Originally Posted by czirrfb3
will that restrict air flow?
It could. Depends on the size of the filter. They are primarily used in off road situations as a pre filter to repel dirt and some water.
I use an alternative which may sound silly but works great, and its cheap. Panty hose. I don't care about heavy dirt and water, but do care about the sand and debris that accumulates quicker on the filter due to my cold air snorkel. Quite a bit of road debris over short time gets on the filter because of that direct airflow. The panty hose breathes extremely well like nothing there, but has a really tight fine mesh that blocks all but the extremely fine dust. Keep the filter cleaner much longer and protects it.
Old Feb 11, 2019 | 07:47 PM
  #23
czirrfb3's Avatar
Very interesting idea with the pamty hose I'll try that
nice_tan
Apr 13, 2011 06:17 AM
dtkix
Jan 12, 2011 12:01 PM
radtech
Feb 10, 2009 05:16 PM
cuonice
Feb 15, 2006 03:20 PM
SC2000S2k
Oct 7, 2005 06:37 AM
