Dome light switch not working. Lights work
Originally Posted by Vatko' timestamp='1312175086' post='20834256
Speaking of domelight/spotlights.. mine don't work at all. I suspect is a blown fuse.. anyone knows where that fuse might be, and which one in particular is it? 10x
Finally was able to do this! Took about 5 mins and recommend using the 8mm than the screwdriver lol And I just used a scouring pad aka the green dish washing pad, dry one of course to get rid of the corrosion! Took it clean off!!! I have dome lights now!!!! Thank you for the write up!!!
so every function of my light works EXCEPT for coming on with the doors. works when i lock/unlock with the remote as well as key in/out of the ignition. Is my light functioning differently due to the factory alarm being installed? i just wish i could extend the self arm time so that it stays on a tad longer.
Originally Posted by AZS2KDancer
My dome lights work when the drivers door opens, but not the passenger door. Could this issue be the dome light contacts or something else?
It happens to me too, the switch has to be exactly in a certain position for the lights to come on. Unfortunately that position is not where the switch clicks but like half a mm off, and if it's not exactly there it's like the lights were off.
