Downshifting to the correct gear?
Originally Posted by Fasttimes!!,Dec 3 2005, 07:02 PM
Anyways, when I down shift I need to be in power band always to maximize power? So if I am going 55 and downshift to 3rd I dont believe I will be in powerband right away? So if I go to 2nd of course I am in power band but need to shift quickly?
Correct me if I am wrong.
FWIW!
Drive Safe,
Steve R.
Originally Posted by Empedocles99,Dec 5 2005, 02:43 PM
Does "rev matching" always refer to double clutching? Or is it considered "rev matching" when you blip single clutch downshifting with the clutch pedal down too?
Rev matching is simply raising (or lowering) engine rpm to a point that "matches" the speed it needs to be for the next gear whether that gear be up or down.
Double clutching involves the going through neutral in such a way as to "connect" the tranny back with the engine (clutch action needed) so that the tranny can be spun up (or down).
To make things even more spicey, you can throw in a "heel/toe" manouver, but since you didn't ask, I won't complicate things any further.
Spec_Ops2087
Jul 11, 2007 06:24 PM
