early rev limiter with weak vtec
Old May 11, 2005 | 08:50 PM
panda007's Avatar
Default early rev limiter with weak vtec
Hello. I posted before because of the map sensor symptoms, however that doesn't seem to be the case...
The symptoms included:
-weak vtec... the engine struggles past the vtec point.
-early rev limiter... the engine struggles until it hits 8600~8800 rpm, hesitates then drops down even with the gas pedal at WOT.
A few hours ago, I installed the new map sensor and zip-tie from HardTopGuy and disconnected the battery to reset the ecu. After, I took the car on a 30 minute 'spirited' driving just to see if the problem has been solved however the symptoms remain. Engine has been warmed up to 3 bars, oil at high level and CEL was not on. Woe is me... don't know what is up with the car.
I am thinking perhaps it's a slipping clutch.
Anyone would like to chime in?
Old May 12, 2005 | 07:00 AM
xviper's Avatar
If you are having a difficult time telling the difference between a VTEC issue and a slipping clutch, you need to find someone who CAN tell the difference or you'll be pulling your hair out for a good long time before resolving this. You need a professional to check your car out in person.
JAYDM919
May 19, 2025 05:02 PM
killboy
Sep 23, 2013 04:32 PM
s2kmanuman
Sep 3, 2008 10:42 AM
HondaS
Jul 13, 2008 03:38 PM
frofro24
Dec 10, 2005 12:08 PM
