ECU throwing code after intake modification
Old Jan 30, 2007 | 04:51 PM
kOOpA's Avatar
Default ECU throwing code after intake modification
Heyah howdy. My friends and i were putting a Koyo radiator in my S a few weeks back. Problem is, the radiator was so big that we had to remove my airbox. In the process of removing the airbox a hose was left just sitting there (did go into the passenger's side of the airbox i believe). And now my car's ECU is throwing a code, i forget what the specific description was, had something to do with intake tho, so i'm assuming that hose is causing the problem. As of now i have it ziptied up by my intake for easy access.
Would it be ok to just clog the sucker up, remove it, or what? Thanks very much in advance!
-Josh
p.s. i was going to do a search for the problem, but really couldn't think of what to search for
Old Jan 30, 2007 | 05:24 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
It all has to be hooked up exactly, or the CEL will never go out.
Like so...note the direction of the little white check valve....
Old Jan 31, 2007 | 05:06 AM
kOOpA's Avatar
okie dokes i'll see if i can get it taken care of, thanks!
Ddub-S2K
May 15, 2010 06:30 AM
05AP2S2k
Dec 28, 2008 01:01 PM
kOOpA
Feb 27, 2007 06:17 PM
LivingLegend
Nov 1, 2004 01:37 PM
infinitebass
Oct 13, 2002 07:19 AM
