Engine
Old May 3, 2005 | 11:08 AM
Louise's Avatar
Default Engine
How do I disassemble the oilpump from the engine?
Or where can I buy a Work Shop Manual covering engine and transmission?
Louise
Old May 3, 2005 | 01:05 PM
mikegarrison's Avatar
http://www.helminc.com/helm/search_service...p?class%5F2=AHM
Old May 3, 2005 | 11:10 PM
Greenlight's Avatar
The engine oil pan and the timing chain cover must be removed in order to remove the oil pump.
The oil pump is attached with three bolts, two 12mm head and one 10mm head. All of these are accessible after the oil pan is removed.
The oil pump chain tensioner must be removed prior to removing the oil pump bolts. The tensioner is located under the timing chain cover and is attached with one 10mm head bolt and one12mmhead bolt.
S2k_razy
Mar 30, 2015 07:30 PM
braeden
Feb 9, 2015 11:51 AM
jjost15
Feb 10, 2012 05:30 AM
Irishflame27
Jun 21, 2010 11:10 PM
mikey k
Jan 20, 2010 09:58 PM
