Engine done
Old Feb 27, 2016 | 06:02 AM
  #21
Car Analogy's Avatar
I would file a small claims court suit. Its not expensive, don't need a lawyer. Dealership may cave and pay to avoid bad publicity from a potential loss in court on their record.
Make sure you bring copies of everything, every receipt, etc.
Best to explain to judge in clear, concise, non-technical jargon. If you can get shop that fixes car to state what they think happened, that would be great. Get them to write it out on their letterhead, etc.
Sent from my SM-G920P using IB AutoGroup
Old Feb 27, 2016 | 06:15 AM
  #22
Langelo DeMysterioso's Avatar
Better Business Bureau
Old Feb 27, 2016 | 06:36 AM
  #23
Chuck S's Avatar
Good luck.
We're wrecking AP2s every week and Ebay has pages of complete engines. Some complete with transmissions.
-- Chuck
Old Feb 27, 2016 | 01:58 PM
  #24
Ets2k05's Avatar
Originally Posted by Chuck S
Good luck.
-- Chuck
Thanks. Is the F22C the same across the AP2 line? Mine is a 05. Or does it have to be a 04/05 motor?
Old Feb 27, 2016 | 06:55 PM
  #25
bgoetz's Avatar
04/05 is best. 06+ isn't as straight forward.
Old Feb 28, 2016 | 09:33 AM
  #26
Ets2k05's Avatar
Yeah that's what I thought. Unfortunately for me the pages of engines on eBay seem to be 06+. Thanks for the info. I'll keep looking.
Old Feb 28, 2016 | 10:27 AM
  #27
Ets2k05's Avatar
Originally Posted by Billman250
If your car had a broken retainer, I can guarantee it was overlooked by the dealer.
Pull the cover and do some assessment, look for broken retainers or loose adjustment nuts.
Thanks. How does one end up on a list for a short block if I wanted to replace it? Or is that a Jedi level trick? I will get around to posting pictures of all this soonish. The Army is demanding on my personal time lol.
Old May 6, 2016 | 04:51 PM
  #28
Ets2k05's Avatar
Well thanks to some folks on here and TAE, the engine has been swapped and I'm running strong. Thanks for your ideas, smart-ass remarks and thoughtful insight! I will get pics up she is cleaned.
Old May 7, 2016 | 02:27 PM
  #29
snitm's Avatar
Given you're in VA you should seriously consider having InlinePRO build you an engine and install it.
edit: oops, missed your most recent post, InlinePRO is likely way more than you'd have wanted to spend anyway.
Old May 8, 2016 | 08:01 PM
  #30
InTheZone's Avatar
Originally Posted by Ets2k05
Originally Posted by Chuck S' timestamp='1456587362' post='23892668
Good luck.
-- Chuck
my 05 s2000 has an engine swap from an 08 or 09 CR, I forget which year but I bought the entire longblock, header, intake manifold, clutch/flywheel/pressure plate off ebay.
like the poster above stated, it wasn't as straight forward. The shop told me the air pump can no longer be used and I had to buy an izze-racing air pump simulator to get rid of the check engine light(has worked perfectly going on 4 years now). The shop did have to use my original intake manifold/throttle body, valve cover, cam position sensor, cam wheels, and crank wheels. The shop did not swap the crank wheels originally and my car would get a CEL and go into limp mode where I could barely drive it if I hit high rpms. Instead of taking it back to them since they would charge me more I simply dropped the oil pan and pulled the timing cover to change the wheel out myself. 40,000 miles later still going strong no CEL and the engine has about 20k less miles than the car...
gomboy86
Aug 16, 2017 05:49 PM
MarcS2000
Sep 27, 2016 02:35 AM
Mad Mart
Aug 19, 2013 09:14 AM
tugsta
Jan 7, 2012 07:24 AM
