Engine idle bog, dip, studder, stalling, etc
Old Aug 29, 2013 | 02:12 PM
  #41
WikkedTIki's Avatar
Could this problem also include shuddering/stalling when starting to accelerate from a stop? I get a slight shudder sometimes when stopping quickly, but its more noticeable at times when starting.
Old Mar 29, 2015 | 11:33 AM
  #42
ScottS2ki's Avatar
Great info this is what mine is doing, I have just got it, its been parked for months and had a flat battery
Old Mar 31, 2015 | 03:10 PM
  #43
Mike in Detroit's Avatar
Great thread
Old Jul 2, 2016 | 03:32 PM
  #44
S2K-OED's Avatar
I had this issue and getting a new battery resolved it.
Old Oct 17, 2016 | 06:54 PM
  #45
vicdeng's Avatar
I just had the same experience for about 3 weeks of ownership. It never do that in this past 3 weeks. Tonight, i went out to get gas. Everything is find until i was on my way home, and coming to a roundabout, i brake and slow down the car, downshift to 2nd, and then the car stalled. NO CEL. I was stopped in the middle of the road. I tried to restart the car, it was difficult to start. It cranked, but did not start.
I tried to restart twice, and it didn't work. After 30 seconds, i tried again, and it started right up. i couldn't seem to find anything wrong with the car, i didn't feel the engine is bogging or bad idles, etc.
This happened again when i am approaching my driveway, downshift to 2nd, and speed is quite slow as i am getting ready to get on my driveway ramp. It stalled. And again, i had difficulty to start the car immediately. I have to give it a decent 30 sec to a min, it started right back up.... Still no CEL....
what's the problem here? i don't wanna get strand in the middle of the road again. It was quite dangerous.
Old Mar 25, 2017 | 09:56 AM
  #46
licelsior's Avatar
I got into this situation here also where it stalled out and took a bit longer to crank over in traffic on a highway.
I have replaced the MAP sensor and the IAC motor with OEM units and its still acting the same. I've cleaned out the TB but I have a feeling it may be a sticky butterfly that could be causing this.
Old Mar 25, 2017 | 10:18 AM
  #47
Hfreak's Avatar
I would check the engine ground cable on the back of the head, this seems to cause different issues and replacing it has helped many owners.
There is a recent thread describing this. Good luck.
https://www.s2ki.com/forums/s2000-un...ts-up-1108318/
Old Mar 25, 2017 | 12:55 PM
  #48
licelsior's Avatar
thanks Hfreak, i just took the car out and i noticed the car had stalled even when it was dropping back to idle at 5-600 rpms.
Old Apr 18, 2025 | 01:26 PM
  #49
jimcity21's Avatar
Wouldn't it be easy to just replace the IAC as another option? they are like 80 bucks...
Originally Posted by Wisconsin S2k
This question gets posted a TON. The symptoms are any of the following:
Engine idle dips really low when coming to a stop, and car sort of "shudders" because rpms get down to 300-400 rpm.
When at a stop, after giving a small amount of gas, and then pushing the clutch back in, such as backing out of a parking space, etc, the engine idle dips low and almost stalls.
Any other variation of the above. I will add other specifics as they become available.
So now that this happens, here are the steps and solutions to this problem.
First, understand that our ECU is a "learning" ECU. It is taking readins from many different sensors and adjust timing and fuel mappings based on the readings it gets from these sensors. At times, the readings can conflict for one reason or another, and cause the ECU to become confused. This is THE MOST COMMON reason for this bogging idle.
When this happens, DO NOT give the car gas, as it makes it more difficult for the ECU to "relearn". This ECU confusion occurs most often when there is a big change in temp or humidity in the atmosphere.
So:
1. Give it a couple days. The idle problem will most likely go away on its own. Though keep in mind it can come back again when the same conditions occur again! This is normal for our cars!
2. If after several days, this problem is still constant, try the "map sensor whack" located here:
https://www.s2ki.com/forums/index.php?showtopic=209708
Also, securing the map with the "zip tie" method may help.
3. If this does not work, clean the IAC motor. I will provide more specifics and possibly pictures on how to do this if I can. When you clean the IAC motor, if you notice a lot of oil and very thick crud in the area, you may need to install a catch can or figure out why you're getting so much oil blow by into your TB area from the PCV.
4. If that still does not work, you may need to replace the map sensor. (this does happen!)
5. If that doesn't work, then you may need to replace the IAC motor, though generally, this causes a high and low erratic idle when it goes bad.
A.VOID
Jul 12, 2010 05:53 PM
s2k_PikeStyle
Jun 17, 2006 06:17 PM
AustinS2k2003
Apr 5, 2006 05:31 PM
MechaGodzilla
Apr 4, 2005 10:33 AM
dereks2000
Feb 20, 2003 06:54 PM
