engine oil change
Jeez man, where did you learn how to type? Do you Speak Canada or what?
Yes, you should change the oil after sitting for a long time as there can be some condensation buildup in the oil. Also I heard that old oil can turn acidic after a while. Not sure if the acidic thing is true or not but anyways, oil is cheap, its the lifeblood of the engine. Just do it...
Good Luck
Good Luck
