Engine Problem
Old Jul 2, 2002 | 09:17 AM
  #21
marcucci's Avatar
Is "TypeS" wishful thinking, or do you have a Type S motor in the car?
I would not suspect your change interval though I would suspect your oil choice. How long have you been running oil thicker than 5W30? What did you run in winter?
The 7000 mile oil change interval would not have been a problem as long as the oil level was OK. The problem is that the H22 consumes a fair bit of oil, especially when pushed hard. As such, it is not uncommon to run the motor dry enough that bearing damage can occur. I have to admit I'm a little surprised you have ring damage.
Old Jul 2, 2002 | 09:38 AM
  #22
TypeS's Avatar
[QUOTE]Originally posted by marcucci
[B]Is "TypeS" wishful thinking, or do you have a Type S motor in the car?
Old Jul 2, 2002 | 10:53 AM
  #23
marcucci's Avatar
If that's the way you've been driving the motor, it doesn't surprise me that you've damaged the rings. In fact, I think it explains it. You've been using oil weights in the summer which I think are far too thick for the motor to adequately lubricate itself. You were probably running the bottom end "dry" for the most part with an oil that thick.
10W30 is too thick for the H22, period. Anything thicker than that is too thick. The cooling system is more than adequate to prevent the need for a heavier weight oil than 5W30 which is the recommended viscosity.
Doesn't change the fact about your motor... but I would suggest thinner (recommended weight) oil on the next one.
Old Jul 2, 2002 | 11:23 AM
  #24
ccarnel's Avatar
Marucchi, why does Honda dictate 10w30 for our engine??
Old Jul 2, 2002 | 11:46 AM
  #25
marcucci's Avatar
You'll need to ask Honda.
I've heard 5W30 is compromised somewhat in flash point due to additives to get the large viscosity spread. Perhaps they think 10W30 is a "stronger" oil. Not sure, but I know that the design dictates the oil required, hence why I stick with 10W30 in the F20C.
Old Jul 2, 2002 | 11:53 AM
  #26
hyperpm's Avatar
How about 5w30 Redline? Is that good weight for S2K?
Old Jul 2, 2002 | 11:58 AM
  #27
marcucci's Avatar
I'd stick with 10W30, regardless. With 5W30 my valvetrain noise increased a lot (I tried it to see if the noise was inadequate oiling on startup... apparently not).
Old Jul 2, 2002 | 12:13 PM
  #28
hyperpm's Avatar
Marcucci
I was actually going to use Redline 10w30 but store only had 5w30 and 10w40 so ended up with 5w30.
Hyperpm
Old Jul 2, 2002 | 12:41 PM
  #29
TypeS's Avatar
[B]If that's the way you've been driving the motor, it doesn't surprise me that you've damaged the rings. In fact, I think it explains it. You've been using oil weights in the summer which I think are far too thick for the motor to adequately lubricate itself. You were probably running the bottom end "dry" for the most part with an oil that thick.
s2kdriver80
Aug 15, 2014 01:12 PM
Hickey322
Feb 26, 2012 01:12 PM
sbabys2000
Apr 9, 2008 11:48 PM
TR-S2K
Mar 3, 2005 11:53 AM
bguernsey
Feb 16, 2002 03:36 PM
