Engine Checklight is on
Old Jul 1, 2002 | 04:21 PM
chungtaho0918's Avatar
Default Engine Checklight is on
Did anyone change their oem cat?I remove the cat and engine check light is on, is there any way to get rid of the light?plz help...
Old Jul 1, 2002 | 05:11 PM
Schatten's Avatar
did you check the library under troubleshooting?
so, you removed the cat? or what? removing the cat will cause the light to come on.
Old Jul 1, 2002 | 09:09 PM
I removed the cat, and make it straight pipe....is there any way to bypass the light?
Old Jul 2, 2002 | 05:02 AM
turbo_pwr's Avatar
You do know you have a O2 sensor on the cat right? If you remove the cat the sensor has no reading so yes you will get a CEL. There is a way to bypass it but I don't remember so you better start using the "search" feature of this site.
Old Jul 2, 2002 | 06:26 AM
okie I will try to search for it...thanx turbo-pwr.....also I heard that there is a fake O2 sensor that I can buy....is that gonna work?
Old Jul 2, 2002 | 06:27 AM
also I heard that if your engine check light is on in the car, the car will run slower because the ecu is in a safe mode....is that true?
Old Jul 2, 2002 | 06:39 AM
turbo_pwr's Avatar
2 things to consider from reading previous owners experience with straight pipes. Performance gain is minimal to non existent, you get really bad gas mileage, and you get the CEL.
Old Jul 2, 2002 | 03:05 PM
Utah S2K's Avatar
If CEL is "flashing"; OBD-II will likely put the car into safe mode.
Utah
xs2kFanaticx
May 17, 2011 06:13 AM
tmf171
Feb 10, 2011 09:03 AM
Bruinlax
May 10, 2006 06:53 PM
03s2k
Feb 22, 2004 02:14 PM
yellow2001
Jan 17, 2003 07:16 PM
