First gear
Old Jun 4, 2010 | 08:02 PM
  #21
ssthrd's Avatar
Thanks for the technical lession rob-2, but i don't need it. You can have the last word if it makes you happy.
barrett4bama, i've had 2 z28's, a corvette, and now the S2000. I've driven about every muscle car you can name along with a RUF 930 Turbo. All with 4 or 5 speed trannys. almost every one of them has had an issue like you describe but only now and then, and i suspect yours is no different.
At least rob-2 and i agree (I think) that if ,when you are stopped, you hit second before you hit first to pull away, it will probably work fine. if not, you could spend the money on a fluid change--not a bad idea--and if that doesn't work, go to your mechanic or dealer for a professional opinion/fix.
Good luck. Hope you figure it out.
Old Jun 4, 2010 | 08:11 PM
  #22
barrett4bama's Avatar
alright thanks guys, ill get my fluids changed.
  #23
SlideWayz
Aug 26, 2012 04:19 PM
UniqueS2k
Jan 16, 2010 09:32 PM
tonywlim
Apr 9, 2008 01:56 AM
JDMQuip
Apr 6, 2007 09:29 AM
VTEC Racer
Oct 8, 2001 08:18 PM
