Found Coolant Leak
Old Jul 12, 2011 | 05:05 PM
slowpokeS2K's Avatar
Default Found Coolant Leak
Ive recently ran into coolant leak issues and may have found the culprit.
heres what the damage looks like.
how do i go about replacing these pieces? is there anything i need extra or can i just order the bleed valve and hose valve?
Old Jul 12, 2011 | 05:49 PM
Stratocaster's Avatar
That bleeder is part #21 and about 10 buck from your local dealer http://www.hondaautomotiveparts.com/...NTAKE+MANIFOLD
To replace this I would just remove and install the new part on a stone cold motor with the front of the car jacked up to make that the highest point. I don't see anything else that needs replaced. What other part did you think you needed to replace?
Old Jul 12, 2011 | 06:01 PM
in the pic, where it looks like it has branches sticking out. would it be leaking from that valve as well? or is it from the bleed valve that makes it look like that.
Old Jul 12, 2011 | 07:52 PM
That branch as you called it is part of the intake manifold and is pressed in at the factory. I highly doubt that is the source of the leak. It most likely collected the coolant from the bleeder valve just above it. I would replace the 10 dollar part and see if that fixes the issue.
Old Jul 25, 2011 | 04:18 PM
damn that took forever to find
anyways, ive finally got around to replacing that valve but it still leaks from there. would it be safe just to weld that piece shut? or is there something else i can do to stop the leak but still keep the valve functional?
Old Jul 26, 2011 | 04:20 PM
anyone?
Old Jul 26, 2011 | 04:36 PM
vividracing.com's Avatar
Banned
Is it leaking from the threads or what? If you replaced the part with a new one, then it has to be the line.
Old Jul 26, 2011 | 11:23 PM
Not to sound like a retard but when you say "the line" which part would that be? The threads you're referring to before that?
agpaoak
Jul 12, 2017 09:10 AM
Muscle Cars Blow
Oct 14, 2010 10:54 PM
Armend17
May 22, 2010 10:31 AM
SpaZilla
Aug 21, 2005 12:06 PM
