Front grill guard and engine temperature
Old May 23, 2002 | 03:49 AM
mountainrebel's Avatar
Default Front grill guard and engine temperature
Has anyone with a front grill guard noticed any changes in engine cooling after installing it? I am considering putting one on my S, but wonder if it will decrease airflow through the radiator significantly.
Old May 23, 2002 | 07:46 AM
Mikey's Avatar
I recall some tests awhile ago that suggested grills do marginally decrease air flow. But it's probably a wash when considering that they prevent damage by bugs and road debris to the radiator. A crushed radiator certainly isn't working at 100% efficiency.
I use a grill in very hot weather with no problems, but I don't run a front plate.
Old May 23, 2002 | 08:22 AM
Thanks Mikey. I don't run a front plate either.
Old May 23, 2002 | 04:25 PM
KYS2000's Avatar
I bought my s2000 grill from grille-tech.com and even talk to the guy cause the owner has an s2000 also, he says that his grill allow for 68% air flow as compared to 100% without the putting a grill there, i haven't notice a bar of heat increase but some people have with hot temp and driving on an incline, do a search and see.
Old May 24, 2002 | 04:44 AM
KeithD's Avatar
Axcilla, the guy who owns Coastal Metals, has done some temperature testing. Its up on his website: www.hondas2000accessories.com .
Old May 24, 2002 | 07:15 AM
Elistan's Avatar
Coastal Metals grill, no front plate, track event last weekend, about 80F ambient, no problems.
Old May 24, 2002 | 08:23 AM
What about compensating for the decreased air flow by opening the side vents or increasing radiator heat exchange efficiency using Red Line's Water Wetter? I have considered a vented hood; but those are expensive, even without considering painting costs.
Old May 24, 2002 | 05:50 PM
Russ's Avatar
I have a grille and no plate. I also have been using Redline WW for about 2K miles and with previous results from my other cars as a guide, I doubt I will EVER see four bars on the S2K. The stuff works. The radiator is just too damn vulnerable for something NOT to be there.
Old May 24, 2002 | 06:11 PM
I agree. My grill guard should be here next week.
Old May 24, 2002 | 06:38 PM
Mikey's Avatar
Originally posted by Rasputin314
For me, even with a 1% decrease in cooling efficiency, I won't put the grill or a plate on.
That's a false economy. When the bugs and stones bend your radiator fins, you'll efficiency will drop permanently.
I find it far preferable to run a grill. It's easier and cheaper to remove or replace than the radiator.
flanders
May 26, 2016 08:14 AM
Ek_Jak
Nov 29, 2015 11:14 AM
Ludeboye1
May 4, 2012 05:11 PM
GpWaP1 s2k
Nov 16, 2009 02:47 PM
Russ
May 8, 2003 11:24 AM
