Gauge warning limits
Old Nov 15, 2004 | 11:50 AM
GrimReaper's Avatar
Default Gauge warning limits
I just finished installing my oil temp & pressure gauges. What is the recommended limits for the warnings? Also, what should the "normal" readings be? I recall somone posting before, but I can't get the search function to work.
Btw, I'm also using a greddy oil block adapter.
Thanks,
-sam
Old Nov 15, 2004 | 01:23 PM
msm_s2k's Avatar
For oil temp:
- Warmed up at about 80 degrees c
- Sustained driving at speeds to 100+ up hill I've never seen it about 110 c
- Auto-x doesn't ever get that hot 90 to 100 c
- Temp alarm is set at 120 c
For oil press:
- Before the car is warmed up it is mostly around 8
- Onced it's warm it is mostly at around 6
- At WOT once warmed up it gets to a bit above 8.5
- Low pressure alarm is set at 3
I never found much on S2KI or elsewhere, so I just went with the above.
Old Nov 15, 2004 | 03:47 PM
GrimReaper's Avatar
Thanks for the info. I was reading about 90C on the commute into work this morning and thought it was a little high. Also, what is your unit of measure for the pressure?
Old Nov 16, 2004 | 05:45 AM
modifry's Avatar
Honorary Member
My guess is "bar". (and I mean a guess, I don't know fer sure)
I think "bar" is from "barometric", meaning 1 atmosphere, or 14.7 PSI. So the alarm at 3 bar is about 45psi.
LukeS2K4EVA
Jun 9, 2011 11:19 AM
Emil St-Hilaire
Nov 10, 2005 02:51 AM
JT-KGY
Jan 1, 2004 12:25 PM
gdw
Jan 19, 2003 09:50 PM
marcucci
Jun 23, 2001 06:21 PM
