Headlight
Old Sep 23, 2015 | 07:06 PM
plizzat's Avatar
Default Headlight
Hello everyone. One of my headlights is starting to change color (left in photo), and actually goes completely out randomly. I assume it's wearing out? Where would you recommend buying new bulbs? I assume it's best to replace in pairs so the colors match? Or is it ok to just replace one bulb? Thanks.
Old Sep 24, 2015 | 05:01 AM
SMG1990's Avatar
The photo hasnt posted properly,
However it is best to change both lights at the same time, I brough a replacement set of mine on ebay and they have been good for almost a year and a half.
Old Sep 26, 2015 | 01:42 AM
Langelo DeMysterioso's Avatar
I get mine right here
The Retrofit Souce
Old Sep 26, 2015 | 03:29 AM
Chuck S's Avatar
Which of the 50 bulbs in the link?
-- Chuck
Old Oct 1, 2015 | 08:44 PM
plizzat's Avatar
Thanks. I replaced the bulbs. The one that went out before stays on for about a minute then going out again. I can turn it back on, but then it goes out again after about a minute. Would this be a symptom of the ballast going out? Thanks.
Update: I replaced the ballast and its still going out...is there anything else that would be causing the problem?
Old Oct 14, 2015 | 07:54 PM
plizzat's Avatar
Update: I replaced the ballast and it's still going out? Could be another part of the headlights? Thanks.
Old Oct 15, 2015 | 06:11 PM
chefs2000's Avatar
I have same problem .. Put my blinker on and the headlights flash .. Also when i hit a bump .. Then driver side goes out .. I turn my lights off and on and it goes bak on.. I hit the head lamp and it doesn't blink .. I also have all aftermarket led and the switched out the blinker regulator box .. Doesn't seem to do it when my brights are on but not totally sure
Old Oct 19, 2015 | 11:27 PM
plizzat's Avatar
Is the problem related to the aftermarket lights or the ballast?
Old Oct 20, 2015 | 03:03 AM
Forziii's Avatar
Has this been happening only recently? And has it been getting cold where you live recently? It could be moisture somewhere playing with it.
If you swap the headlights you had in the beginning of your problem, does the issue switch sides?
Old Dec 17, 2015 | 12:14 PM
TVPincDoc's Avatar
Probably not a bad idea just to avoid having to do the other one in a few weeks. My wife's Highlander burned out a headlamp last Friday. I bought a two pack, but she insisted that I only change the one that was burned out. It wasn't worth the argument, so I changed the burnt out bulb. A day and a half later I was changing the OTHER burned out bulb...
r8byb
Feb 16, 2011 02:31 PM
J.nguyen
Aug 2, 2007 03:07 AM
Touge Freak
Oct 10, 2006 04:42 PM
AustinS2k2003
Aug 4, 2004 10:01 AM
DJSang
May 16, 2004 01:54 PM
