headlight problem
Old Mar 10, 2010 | 09:32 PM
solomonster's Avatar
Default headlight problem
so both my low beams went out....the story was...i guess on the passanger side my tire wore out the wiring..so the right side went out...i fixed it....its been raining alot the past month....and both my lights went out...my high beams still work(hid high beams) i dont know if its the bulb or the ballast...whats the chances of both going out at the same time...all my fuses are good also...how can i check to see if its the ballast if both dont work?
-thanks
Old Mar 10, 2010 | 09:39 PM
fatjoe10's Avatar
If I recall correctly, the high beams are only a 55w halogen bulb.
An easy way that I use to determine if your ballast burned up due to water is to remove it from the housing, and first check for wetness, and then smell the part where the connector goes in. It will smell burnt if that's the case. I lost 2 ballasts due to water.
Old Mar 10, 2010 | 09:43 PM
Saki GT's Avatar
How did your tire wear out a headlight wire?
Old Mar 10, 2010 | 11:14 PM
B serious's Avatar
^The fender liner is probably gone and the wiring's probably in bad shape.
OP: There's a chance that water got in there. Or there may be an issue with your headlight switch or relay.
You really should run fender liners, BTW.
Old Mar 11, 2010 | 01:12 PM
fatjoe10's Avatar
^agreed
Old Mar 11, 2010 | 05:30 PM
hmm yeah maybe water got in...because after all the rain...i did have moister inside the lens....i never had both stop working at the same time
yeah i dont have fender liners...lol im running pulled fenders and all that good stuff =(
K.Shift
Feb 22, 2018 11:34 AM
RichwiththeS2000
Mar 16, 2011 07:16 AM
NAREKS2k
Jan 20, 2010 12:10 PM
keemaca
Oct 22, 2009 11:06 PM
RedhotS2k5188
Jul 23, 2009 06:34 PM
