heat dosnt stay hot?
Old 10-12-2010, 05:29 AM
Devinb's Avatar
Default heat dosnt stay hot?
So i turn the car on and let it warm up then i turn the heat on and it starts to blow nice and warm. Well after a few minutes it will turn to cold air. It will then just go back and forth from cold to hot air, without me touching anything on the temp. control.
Does anyone know what would cause this. I thought something blocking the system maybe?
Old 10-12-2010, 05:33 AM
Billman250's Avatar
Received 1,307 Likes on 795 Posts
Low coolant/air in the system.
Old 10-12-2010, 07:39 AM
ihiryu's Avatar
yeah it needs to be bled. mine was doing that for awhile, but apparently i wasn't bleeding the system right
Old 10-12-2010, 07:53 AM
Devinb's Avatar
how would i properly go about bleeding that. just drain everything and refill?
Old 10-12-2010, 06:24 PM
Seattle2k's Avatar
Old 10-12-2010, 07:29 PM
hellspare's Avatar
Yep my car had that problem right after a motor swap too. The shop drained some of my coolant and forgot to fill it.
Do a flush and you should be golden.
Old 10-12-2010, 07:35 PM
Suzukuh's Avatar
This is the one I used.
http://forums.s2kca.com/showthread.php?t=12152
Old 10-13-2010, 05:51 AM
Billman250's Avatar
Whatever you do, dont follow that procedure from the book. you will overheat the car for sure.
I have posted my bleed procedure a few times.
Old 10-13-2010, 11:28 AM
Boost76's Avatar
X2.. happened to me. I just bled it on an incline & BAM hEAT!
Old 10-13-2010, 05:39 PM
Seattle2k's Avatar
Why is that?
wpg_RSX-S
11-09-2015 03:57 PM
AZS2KDancer
03-16-2014 11:21 PM
jpark
04-09-2013 11:13 AM
02s2k01s4
11-02-2007 10:31 AM
S2Krazy
10-12-2001 04:56 PM
Quick Reply: heat dosnt stay hot?
