help
Old Feb 24, 2011 | 04:30 PM
01spas2000's Avatar
Default help
so i recently had my oil changed. the next day i was driving pretty fast racing evos and what not. later that day i accelerated to a horrific sound. a quite knock when i accelerated. i pulled over and looked at the engine, no oil cap! so my question to you guys is am i screwed or is it just a low oil knock. personally i think im screwed because i checked the oil and there was plenty in the engine. 75k on the car.
thanks
Old Feb 24, 2011 | 04:48 PM
smallville160's Avatar
check your valve clearance
valve adjustments are recomended at 90,000 miles
Old Feb 25, 2011 | 05:29 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Ha!
The oil cap is wedged between the firewall and engine/transmission. This is the knock you are hearing. The engine vibrates the cap against the car and it sounds like an engine knock.
Very common.
Find the cap and put it on all will be fine.
Old Feb 25, 2011 | 05:45 AM
BanzaiS2K2003's Avatar
Bill saves the day again. lol
Old Feb 25, 2011 | 07:52 AM
01spas2000's Avatar
thank you i will check asap
Old Feb 25, 2011 | 08:44 AM
haywoodjablome's Avatar
S2000s don't have a set valve adjustment interval. Service manual states "adjust if noisy". These cars have gone close to 150k without having the valves ever touched.
Good thing Billman stepped in or the guy would have been tearing his valve cover off and doing unnecessary work and possibly making things worse.
Old Mar 6, 2011 | 03:02 AM
Billman250's Avatar
Top Answer: 1
did you find your oil cap?
Old Mar 6, 2011 | 06:09 AM
Uncoolron's Avatar
Unbelieveable, he comes in asked for help and don't even...come back and say something.
Old Mar 7, 2011 | 03:24 AM
VAD's Avatar
VAD
I dropped my cap down there once. I bent a coat hanger and stuck it down there to retrieve it. It was actually kind of nerve-wracking.
alcollins85
Dec 15, 2009 09:47 AM
AIm2kil
Sep 18, 2009 08:39 PM
GpWaP1 s2k
Mar 15, 2009 11:16 PM
jcastaldo
Jan 2, 2009 08:31 PM
topcat7111
Aug 12, 2005 09:22 PM
