HELP ! Overrev
To the OP: Since you have an 2006 ECU, its going to store the overrev code in the ECU. If your car is ever in for warranty work that is engine related, a Honda Tech's first instinct is going to be to pull the code and see whether the engine has been overreved. I'm not sure that there is anyway you can wipe this code from the ECU.
Originally Posted by Billman250,Mar 5 2007, 06:10 PM
I Usually have a tech day before the Dragon....April 1st maybe.
If you and chad want to put together a quick tech day on the Island, get some peeps, stuff some Dunkin Donuts down my throat, I'll be glad to check em for ya
ill speak to chad about it and pm ya! also ill post in metro if it gets put together
-dave
that sucks....hopefully my dealership will look past that lol.....
ok fine....very hopefully.
Originally Posted by Billman250,Mar 5 2007, 08:47 PM
If you're looking to get just the valve cover pulled for inspection, I can get you in sooner.
Obviously combined with a once over I'll need a bigger window.....
Originally Posted by Sfkn2,Mar 6 2007, 04:42 AM
I went into 2nd gear at 75 last time.. it's still good.
You'll notice it if your car runs/idles weird..
A broken retainer will not affect the idle or the running condition, and it will make no noise at all.
Originally Posted by Billman250,Mar 6 2007, 06:27 AM
You'll notice it when the valve drops for sure
driving home last night, I seriously don't know how I put it in 2nd instead of 4th. I had to go all the way to the left of the shifter to get into 2nd. Oh well, shit happens I guess.
The car runs and idles fine but will be checking my retainer soon. To do that, all I need to do is open the valve cover and use a dental mirror to look? Do I turn the crank at all?
