HELP ! Overrev
Old Mar 6, 2007 | 08:54 AM
  #41
DarkSigma's Avatar
I don't even use 6th gear, and if I ever do I go to 5th then to 4th. This move seems to cause more bad than any 2 seconds you save by skipping 5th.
Old Mar 6, 2007 | 08:56 AM
  #42
Sfkn2's Avatar
What's funny is that when I shifted into 2nd gear at 75, I broke my axles.. I have no idea how that happened, but had the CV joints replaced because it started shaking a lot afterwards.
Old Mar 6, 2007 | 09:15 AM
  #43
mikegarrison's Avatar
You look for the top of the valve stems appearing to sink down into the retainer. There are numerous topics in this forum with pictures.
Old Mar 6, 2007 | 02:48 PM
  #44
silvermonster's Avatar
there is no need to do anything else besides taking off the valve cover and inspecting the retainers?
Old Mar 6, 2007 | 02:56 PM
  #45
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Keep in mind this pic is from an AP1. The AP2 retainers are different, and may not show the exact same difference as the AP1. I stand on my opinion that cracking an AP2 retainer AND showing no symptoms is near impossible. At the speed it would take, the exhaust valves would hit the pistons first.
Good retainer on left.............................................. ..Broken retainer on right.
Old Mar 6, 2007 | 03:58 PM
  #46
found this thread while researching:
https://www.s2ki.com/forums/index.ph...=236314&st=150
good thread to read
and thanks billman250 for the picture. So a broken retainer will have the middle part level with the retainer?
Old Mar 6, 2007 | 05:13 PM
  #47
Davizzle's Avatar
thanks to billman for letting me sleep at night lol!! i trust his opinion that i would show symptoms....either way on thursday me and milkbubble will be playing dentist with the dental mirror lol
Old Mar 6, 2007 | 05:15 PM
  #48
Davizzle's Avatar
oh also billman what symptoms would i generally be looking for with a cracked retainer bad valve...cuz maybe i'm overlooking the small symptoms =\...
Old Mar 6, 2007 | 05:16 PM
  #49
Jsmply's Avatar
I agree, Bill's opinion is one of the ones I don't question. Bill, you said the AP2 retainers would look different in your above post, do you have any clue what you would even look for in checking if the retainer is bad?
Also, Davizzle and all else concerned with over-revs, you really might want to consider getting the shfit beeper from modifry. One of its function is highest engine RPM playback . . . it really clarifies these "I think I might have hit xxxx RPM."
Old Mar 6, 2007 | 06:18 PM
  #50
ShocK's Avatar
Middle part = top of the valve stem, and yes.
