Help/Tips on installing steering wheel/airbag.
Old Feb 19, 2007 | 09:39 AM
MuckaLun's Avatar
Default Help/Tips on installing steering wheel/airbag.
Tried searching and couldn't find any info...
How do i replace the MOMO steering wheel with the factory wheel?
I just want to bolt the thing back on so that i can get the horn/cruise control working again..
any help would be greatly appreciated
Thanks
Old Feb 19, 2007 | 04:48 PM
SenderGreen's Avatar
SRS unit is a one shot deal. If the airbags deployed and the SRS unit was not replaced, it will need replacing if you are trying to get the SRS system back online. Also I think the seat belt pre-tensioners are a one shot deal also, so if they were not replaced at the same time as the seat belts they may also need replacing to get your SRS system functioning. Also as far as I know if your SRS light is ON, the SRS system is disabled and will not deploy.
I would recommend that any work on the SRS be done by proffessional. Good luck
Old Feb 19, 2007 | 04:53 PM
C4SxM5's Avatar
Airbags will not deploy if you don't change the SRS module. So basically if you rehook up a new driver airbag and don't change out the srs module and srs reel (behind the airbag) then they won't work.
Old Feb 20, 2007 | 09:12 AM
MuckaLun's Avatar
Thanks!
leftyz
Aug 24, 2011 03:53 AM
twofast4u
Jul 11, 2009 06:41 AM
MrRxZoCo
Jun 14, 2009 01:12 AM
midnightmethane
Mar 31, 2008 05:37 PM
trivium
Jul 25, 2006 04:55 PM
