Help with trickle charging
Old Feb 19, 2014 | 11:48 PM
1RM's Avatar
1RM
Default Help with trickle charging
Hey guys,
As topic states I need some help with my battery. I have purchased a CTEK charger and want to begin trickle charging the battery (don't drive the car often) whilst it's in the car.
I have been told not to connect the negative connection to the battery. Is this right? Do I need to connect it to the chassis or is having both the positive and the negative on the battery fine?
Thanks
Old Feb 20, 2014 | 06:40 AM
GSteg's Avatar
You can leave both clamps on the battery. The CTEK charger isn't putting out a lot of amps relative to jump-starting your car.
Old Feb 20, 2014 | 08:17 AM
Abysm's Avatar
I connected both ends works fine like that. Got worried while we had some -30 c weather but the unit kept having the light green lit. No experience by plugging the negative end to the chassis however. Unit has been plugged since November.
Sent from my Galaxy Nexus using Tapatalk
Old Feb 20, 2014 | 12:32 PM
darcyw's Avatar
i have the CTEK as well. Connected red connector to the battery positive, black connector went to the ground on the top/back of the intake manifold. my buddy connects his direct to the battery- he has the same charger.
darcy
Old Feb 20, 2014 | 12:41 PM
zeroptzero's Avatar
Same charger here, I connect it to the battery but either way is fine.
Are you using an AGM style of battery like Optima, Braille, Oddysey ?. In case you have an AGM battery the snowflake charging setting works best with the CTEK chargers. They are great chargers BTW.
Old Feb 20, 2014 | 01:41 PM
AZfury's Avatar
Either way is fine
Old Feb 20, 2014 | 02:16 PM
SheDrivesIt's Avatar
CTEK chargers are the shiznit.
Old Feb 21, 2014 | 04:07 PM
1RM's Avatar
1RM
Where is the ground on the top of the inlet manifold? Am I blind or is it hard to get too? Anyone got a picture?
1RM
Jun 26, 2024 08:27 PM
jpembry
Dec 30, 2011 06:33 AM
F20C_S2k
Dec 8, 2003 02:23 PM
F20C_S2k
Dec 8, 2003 12:09 PM
Maca
Jul 19, 2002 02:21 AM
