HID Problem need help please
Hey people recently one of my HID lights stoped working completly and i was wondering how i can solve wat the problem is and if i should do it alone or get a auto electrician to have a look at it and fix it or maybe even a honda dealer??
I was thinking of trying to find the problem myself but what do i need to do in order to fix it it seems there isnt much room to get to the HID from the engine bay do i need to remove the bumper and headlights???
btw wat type of bulbs do the HID use? h4 h3 etc? thanks heaps help would be appreciated ive asked around with friends they said best to ask on this forum
cheers
cheers
Check fuses first.
Then open the underhood fuse box, and swap the 2 headlight relays. easy enough. If they check out (in other words, same light is still out), only then move to the headlight, start with checking the connection.
ok...... you need t25 tamperproof torx bit to open the cover to get to the hid bulb......or do what i did and used a needle nose to loosen it up. bulbs go for 27 bucks shipped on ebay. And as far as taking off the bumper...you could actually reach into the holes under your hood. Its a tight squeeze but very possible.
Nah, remove the underfender liner instead. It takes longer, but believe me, your bumper paint will thank you many times over.
My friend bought a pair of ebay HIDs for like $100 for his BMW. He has zero low beams, and high beams only work halfway. It sucks!
S2000_UK
Jul 13, 2007 02:38 PM
