High RPM smell.
Old Apr 28, 2010 | 02:41 PM
songeui's Avatar
Default High RPM smell.
Hey guys im new to s2000s. I just bought a 2002 with 73k miles. When ever I take it to higher rpm( about 5K+) i get smell from the engine. I can't tell what it is. Its not rubber, braks or clutch. Is this normal or should i get it checked out? It's usually pretty warmed up when i rev it high, oil at 3 bars and city driving for about 15 mins. Also i found out today that the last oil change (pervious owner) was with 5W-40 oil, is this ok?
Old Apr 28, 2010 | 02:52 PM
alexisthemovie's Avatar
it's burning oil
Old Apr 28, 2010 | 02:55 PM
songeui's Avatar
no its not an oil smell it smells kinda like plastic.
Old Apr 28, 2010 | 04:19 PM
AusS2000's Avatar
Does it smell like burnt rubber? Mine makes this smell at high RPM.
Old Apr 28, 2010 | 09:16 PM
ssthrd's Avatar
Check out this thread. Same thing. My H22 prelude did it as well as my '05 S. Neither used oil. It's the nature of the beast I think.
https://www.s2ki.com/forums/index.ph...T&f=1&t=171396
Old Apr 29, 2010 | 04:29 AM
ljsimp's Avatar
Since you just purchased this car I would automatically change the plugs, dif fluid, trans fluid, radiator fluid, and engine oil.
I would also inspect the clutch fluid, and brake fluid to make sure they are clear and not pure black. A lot of owners that have no clue never change their fluids except oil.
Some may say your crazy but I have seen stupid things from all my used vehicles that I have purchased from people.
Also the smell may be your drive belt?
Old Apr 29, 2010 | 04:54 AM
dammitjim's Avatar
Check and see if you have a test pipe instead of a cat.
Old Apr 29, 2010 | 06:58 AM
s2klariat's Avatar
Do you have a check engine light?
VilleS2K
Jul 11, 2015 04:47 AM
Green Tea
Aug 15, 2008 07:21 PM
Nick.
May 26, 2008 09:42 AM
Xiao Li
13
Sep 13, 2005 10:47 PM
Eze8199
Mar 20, 2003 05:19 AM
