Higher the rev, lighter the clutch.
Old Jun 4, 2006 | 06:55 PM
MrChoi's Avatar
Default Higher the rev, lighter the clutch.
i dont think this is normal but the feel of the clutch lightens as the revs of the engine increases. i had the clutch replaced a few months ago along with comptech flywheel and a new oem pressure plate. throw out bearing was also changed.
there is also a grinding/rubbing noise when i depress the clutch. this sound is audiable when the clutch pedal is depressed about 60-70% down with a slight amount of throttle. anyone have any ideas?
Old Jun 5, 2006 | 09:17 AM
cdelena's Avatar
There is nothing in that mechanism that can change the pedal pressure or have much affect on feel with RPM. I can only suggest it is a perception change that goes with the increased noise and vibration at higher revs.
Old Jun 6, 2006 | 07:54 PM
MrChoi's Avatar
its not preception. i plugged my ears and closed my eyes and reved the engine on a stand still and played with the clutch and there is a difference in pedal pressure as the rpm speeds up. if i were able to measure the pedal pressure it'll change greatly after 6K rpm. my friends s2k does this as well. i have no idea.
Old Jun 6, 2006 | 08:53 PM
xdavieexx's Avatar
i wouldn't want to drive near you, when you have eyes closed and ears plugged. haha
wankun
Oct 26, 2016 01:18 PM
steamedturtle
Apr 23, 2013 11:42 AM
Spiny Norman
May 21, 2007 05:31 AM
mpikounis
May 16, 2003 06:16 AM
mrsoften
Mar 19, 2002 04:35 AM
