How are the brake lines routed?
Old Jul 6, 2005 | 11:17 AM
tizbad2k's Avatar
Default How are the brake lines routed?
Are the two fronts and two rears tied together respectively, or is it somthing like fl+rr and fr+rl ?
Old Jul 7, 2005 | 10:27 AM
slalom44's Avatar
Top Answer: 1
All brake systems are paired in front and paired in back. In other words, the two front are paired together. They are pumped by two chambers in the master cylinder. One chamber feeds the front brakes, and the other feeds the back. It is done this way so that if there is a hydraulic leak in one system, the other system can still stop the car.
There is also a proportioning valve that adjusts the relative pressure between front and back to keep a set of wheels from locking up. Vehicles are designed to provide more stopping power to the front brakes because of the dynamic weight distribution during a stop. Just like hand brakes on a bicycle, the front brakes can stop the vehicle much better than the back brakes.
If you want to learn all about it, as well as learn how the anti-lock and power units work on our brakes, check this out:
http://auto.howstuffworks.com/brake.htm
Old Jul 7, 2005 | 04:47 PM
tizbad2k's Avatar
Thanks all for the info , the 2nd reply is what i was looking for,
btw as the 2nd reply implies not all brake systems are paired in the same way, Ive had cars with dual master cylinders, and the s2k is a similar setup to what my previous cars had, where each master cylinder would have cross control so to say.
But thanks again, to both
Old Jul 8, 2005 | 08:48 AM
slalom44's Avatar
Top Answer: 1
Originally Posted by hecash,Jul 7 2005, 04:51 PM
The S2000 braking sytem has a little different configuration than the classic system with proportioning valve alone. The full diagram is in the back half of section 19 of the service manual.
Two supply lines come out of the master cylinder into the abs modulator unit. It appears from the diagram that one branch manages FL and RR while the other manages FR and RL. The modulator unit is controled by the the ABS Control Unit (computer). The control unit is fed information by the wheel sensors and it employes that information to manage the engagement of abs pulsing, the type of abs pulsing and proportion management. There is a proportioning control valve but it only proportions independantly between the two rear calipers.
I only know this because I'm on my third master cylinder. I hope that I don't have to change a fourth. It's a messy job.
Wow. I learned something new today! Thanks, Harry.
Old Jul 8, 2005 | 01:40 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Chrysler uses RF/LR on one side, LF/RR on the other..like an X.
7sins2000
Aug 3, 2018 04:07 PM
Prokaw875
Jan 27, 2016 07:12 AM
Iambob911
Sep 1, 2015 09:10 PM
trackrabbit21
Aug 11, 2015 11:14 AM
