How do I run the A/C fan with the A/C comp. OFF
Old 10-14-2005, 01:05 AM
XXX240's Avatar
Talking How do I run the A/C fan with the A/C comp. OFF
Is it possible to run the A/C Fan without running the A/C Compressor?
I was thinking of disconnecting the supply plug from the compressor,
will this work, or it will disconnect the fan aswell or damage the ecu or something?
Is there another option like taking a fuse off or something?
Thanks...
I want to run the Fan alone, to get more cooling on my radiator.
Cheers
Old 10-14-2005, 03:30 AM
Billman250's Avatar
Received 1,320 Likes on 800 Posts
You having overheat problems?
The one fan is more than capable of handling the task...overcooling will not help.
Old 10-14-2005, 08:48 AM
XXX240's Avatar
Just thought of this to keep the motor safe while racing the car.
I thought of switching the second A/C fan will help cooling the engine.
Am I wrong ?
Old 10-14-2005, 08:53 AM
mad-dog-one's Avatar
I would think that there is plenty of air through the radiator when the car is moving at a reasonable speed and that the radiator fan is most critical, and adequate, when you're stopped or moving slow. Have you got mods or other issues with your cooling system that are creating more heat than normal?
Old 10-14-2005, 08:54 AM
news2kroller's Avatar
i know when i had my m coupe (s54) i had underdrive pulleys and it made a big improvment in power. I got 10-12hp from 2000-7000rpm's, i dont think i have ever seen underdrive pulleys for s2000's though, somone correct me if im wrong.
Old 10-14-2005, 09:36 AM
XXX240's Avatar
You are right.
But I sometimes do little drag racing, and you are left for some minutes queing for your turn down the strip....
So I thought of just running the second A/C fan while waiting...
My car has a Mugen N1 ECu, Mugen Rad. Cap, Mugen Thermostat, Mugen Fan Switch, Megan De-Cat, And I'm waiting for a Rick's Header and a MUZ Snorkel which I will fit hopefully by next week.
simon_2k
07-01-2015 10:39 PM
aphex4000
05-28-2015 03:44 PM
Prestonubc22
06-22-2012 06:55 PM
VashRacing
01-01-2010 09:36 PM
EireannS2k
08-13-2009 04:23 PM
Quick Reply: How do I run the A/C fan with the A/C comp. OFF
