Idle
Old Jul 8, 2018 | 06:23 AM
dannyhsu's Avatar
Default Idle
Does anyone have RPM fluctuations at idle? My '04 will idle at 900 for a few seconds then drop back down to 800 then go back up to 900 again. I believe it's within the normal idle range, but should it be fluctuating like that?
Old Jul 9, 2018 | 04:28 AM
RolanTHUNDER's Avatar
Shouldn't be fluctuating. Have you cleaned your IACV? Try that if you haven't.
Old Jul 9, 2018 | 02:56 PM
clio's Avatar
+1
Ideally you'll need a pentalobe bit to remove the motor and spin the mechanism to alleviate any binding/sticking spots. It's often referred to as cleaning the iacv however the cleanliness of the valve isn't as important as loosening the binding on rotating component.
Old Jul 11, 2018 | 01:04 AM
nubbel's Avatar
Caution when putting the motor of the IACV back on!
The magnet will pull it into the housing and the resulting jerk might knock the two washers (left and right @ 1:09min) out - I lost one in my engine bay and a had to make a new one
Don't forget to perform the idle re-learn procedure:
Mike in Detroit
Dec 10, 2017 09:48 AM
Princeneo
Feb 11, 2012 12:36 PM
comicskot
Jan 31, 2012 02:47 PM
Frunzman
Nov 13, 2008 11:45 AM
Ahnold
Oct 16, 2007 12:24 PM
