innovative mounts
Old Feb 25, 2012 | 05:41 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Default innovative mounts
I deleted the thread I made. gonna wait till all the facts are in. dont want to cause a panic about the mounts yet.
Old Feb 25, 2012 | 06:00 PM
99SH's Avatar
Isn't this the same issue a member saw mid last year?
https://www.s2ki.com/s2000/topic/875...ted-the-block/
Old Feb 25, 2012 | 06:10 PM
ImagineIt's Avatar
the mounts have to "break in" they are really shaky at first week or so.
Old Feb 26, 2012 | 03:15 PM
sata3000's Avatar
that the bolts are too long. they hit the block
Sent from my Galaxy II using Tapatalk
Old Feb 26, 2012 | 09:06 PM
Zoomie's Avatar
Please do weigh in though, once you have decided you know the situation. We respect your opinion around here, and I have Innovative mounts waiting to go in.
Old Feb 26, 2012 | 09:19 PM
Harry Dunn's Avatar
subscribed.
Old Feb 26, 2012 | 09:27 PM
psychoazn's Avatar
Ugh. I have innovative mounts.
Old Feb 26, 2012 | 09:41 PM
Monch's Avatar
I've got a set on order from CorSport. I will verify what hardware they are sending out nowadays.
Old Feb 27, 2012 | 12:49 AM
Kwansu-Dudes's Avatar
Damn this is scary, I Installed my innovative mounts a few months ago. I did not use the oem hardware though(used innovative bolts/washers), I remember hand threading an oem bolt into the right (manifold side) front top hole and it bottomed out rather quick. It was clear that the oem bolt was too long because there was noticeable space between the head of the oem bolt and the washer against the mount. I don't see a problem here unless someone used the oem bolts paired with a lot of force to get them in.
Im going to inspect each mount hole tonight and report back.
Old Feb 27, 2012 | 01:59 AM
Neutered Sputniks's Avatar
Originally Posted by Kwansu-Dudes
Damn this is scary, I Installed my innovative mounts a few months ago. I did not use the oem hardware though, I remember hand threading an oem bolt into the right (manifold side) front top hole and it bottomed out rather quick. It was clear that the oem bolt was too long because there was noticeable space between the head of the oem bolt and the washer against the mount. I don't see a problem here unless someone used the oem bolts paired with a lot of force to get them in.
Same here. Only I installed my mounts over a year ago with the hardware that came with them.
I do recall doing the same thing with the OEM hardware and finding that it bottomed out far too quickly.
What gets me about this is that the torque spec is only 28lb-ft. If you're busting out your block cranking on these bolts, you're doing it wrong. And by wrong, I mean: You shouldn't be working on cars yourself because you 1) cannot tell when a bolt is bottomed out and 2) you cannot follow torque specs.
czirrfb3
Feb 7, 2019 04:33 PM
Mccormick009
Apr 6, 2017 06:49 PM
biker1
Feb 6, 2011 10:29 AM
warrenk05
Jul 12, 2010 08:05 AM
ChefJ
Apr 14, 2010 07:21 AM
