Intake Related Relocation?
Old Apr 30, 2014 | 12:27 PM
mongomery1234's Avatar
Default Intake Related Relocation?
To be completely honest I'm not 100% sure what this is but it's related to the intake I believe. The previous owner of my car had a homemade cold air intake that was trash on it which I quickly replaced. I was just poking around under the hood and noticed that this piece is suspended to an intake tube by a piece of thin string and is In my opinion dangerously close to the engine. What can I do to fix this? I believe I saw something on relocating that piece before but I can't seem to find it.
Attached Thumbnails Intake Related Relocation?-wbrlp0.jpg   Intake Related Relocation?-2q33wab.jpg
Old Apr 30, 2014 | 08:39 PM
96-EJ6's Avatar
Normally that solenoid attaches to either the chassis brace just below it in the photo or the factory airbox (can't remember for sure). Either way I'd just secure it to the brace or wire harness and extend the vacuum lines as needed. You can bend the metal hard lines slightly to create a bit more separation between the vacuum lines an the serpentine belt.
Old Apr 30, 2014 | 08:40 PM
realblag's Avatar
That piece is for the secondary air injection pump. You could replace the pieces of hose with longer lengths and move it anywhere you want it. Before I did away with the air pump system in my car, I relocated that solenoid and the vaccuum reservoir (little black tank looking thing) that accompanies it to under the bracket that holds the cruise control unit. Just make sure you keep all the hose going to the correct spots or you will get a CEL.
Old Apr 30, 2014 | 08:46 PM
96-EJ6's Avatar
http://www.hondapartsnow.com/Page_Pr...8958%201478034
This may help...it attaches to the vacuum reservoir...which gets bolted to the brace lol. Link has a diagram.
Old May 27, 2014 | 08:44 AM
Ive pulled a CEL related to the secondary air injection system now so would the izzy kit to bipass that completely delete all of that also?
Old May 27, 2014 | 09:08 AM
afzan's Avatar
yes the IZZE kit will fix that, that's what it's meant for
Old May 27, 2014 | 10:20 AM
Great appreciate the response. Placing an order now.
Old May 29, 2014 | 09:14 AM
Fokker's Avatar
Stock it is bolted to the box, not the brace. Just inside the elbow connecting to the intake manifold.
bjjs2k
Nov 13, 2010 03:51 PM
d4vid
Nov 10, 2009 06:18 PM
ar311unity
Apr 18, 2009 09:33 AM
DDuds2k
Nov 8, 2006 03:39 AM
