issue with subframe bolts
@Car Analogy and @Scigheras you both mention cutting into the frame rail and one of you used nuts( in plural).
2 questions :
1- did you cut/access from the wheel well side or engine bay side?
2- does the bolt run up a shaft to the nut or is open/exposed inside the frame rail?
@everyone does anyone have a picture of the open frame rails while performing this surgery?
thanks!
2 questions :
thanks!
I cut the hole from the engine bay side, was easy to do since the engine was out of the car.
jsenclosure
May 20, 2017 10:34 PM
