J's Hood bolt question
Old Jul 30, 2004 | 01:36 PM
kevsS2's Avatar
Default J's Hood bolt question
I have a question for all the real J's hood owners. I just got my hood in and the instructions are in Japanese. The hood came with 8 bolts all together. 4 short ones and 4 long ones. My question is does the short ones go to the latch of the hood or to the back to hold the hood up?
Old Jul 30, 2004 | 05:45 PM
bigpurp's Avatar
I used the stock bolts to attach the hood to the car, so the bolts you got must be for the hood latch, although 8 sounds like a bit much.
Old Jul 30, 2004 | 08:13 PM
xviper's Avatar
I don't have the J's hood but my TS hood came with some bolts that attached the hood to pieces of wood so they wouldn't get damaged. Never used those bolts.
Old Jul 30, 2004 | 09:06 PM
kevsS2's Avatar
I just put on my J's hood. It latched without messing around with it. Theres kinda a bigger gap on the drivers side but I can live with that. The only problem I had was the windshield washer nozzels dont fit. The hoods holes are too big. Im going to Epoxy them on the hood. I drilled holes under the hood so I can zip tie the water tubes to the hood. Thanks guys !!
Old Jul 31, 2004 | 05:05 AM
bigpurp's Avatar
Keep in mind you can adjust the latches that connect the hood to the car to get a "perfect" fit. Click HERE.
Old Jul 31, 2004 | 12:17 PM
kevsS2's Avatar
Thanks guys!!
jt12soccer
Apr 20, 2009 12:00 PM
Saki GT
Jun 16, 2005 03:56 PM
Red_Ohio_Rocket
Jul 25, 2004 05:26 AM
