Just changed my diff fluid from redline to amsoil
Old Nov 4, 2004 | 07:59 PM
jojipoji's Avatar
Default Just changed my diff fluid from redline to amsoil
My first diff change was with mobile one. During my first change I found lots of metal shavings and metalic goo (oem fluid). Ever since, I have been changing my diff fluid with mobile one, but the last change I decided to use Redline to see if I could tell a difference. The amount of metal goo I found resembled when I first changed the fluid. It was pretty shocking because when I would change with mobile one i hardly found any metal goo. So in very unscientific terms, I will not be using redline because it appears that it doesnt do as well of a job as mobile one. Right now I put in amsoil to see how that would work.
Old Nov 4, 2004 | 08:31 PM
xviper's Avatar
I guess you missed this thread:
https://www.s2ki.com/forums/index.php?showtopic=141409
Did you use Shockproof? If you did, then it doesn't last long. It's good protection for high shock/load applications but you can't leave it in for very long.
Old Nov 4, 2004 | 09:30 PM
Ludedude's Avatar
Administrator
Which redline fluid? How long between changes? That makes for useful information.
Old Nov 5, 2004 | 05:36 AM
TubeDriver's Avatar
I use Amsoil 90w gear oil (not sure they make it anymore but I have 6 bottles in the basement). Seems to work fine.
Old Nov 5, 2004 | 08:17 AM
jojipoji's Avatar
I used shockproof and i left it in about 20k (I do a lot of highway mileage).
Old Nov 5, 2004 | 08:22 AM
xviper's Avatar
If you check the analysis for Shockproof in that link I put up, after only a few thousand KMs, it showed that the protection ability of this fluid was GONE.
Old Nov 5, 2004 | 10:57 AM
Ludedude's Avatar
Administrator
It sounds to me like you may have misused or misunderstood the product.
Shockproof is meant for heavily loaded racing diffs in vehicles that see frequent change intervals. It's not really made for use in daily drivers. Redline makes other oils that are more appropriate for that use, namely a 75w-90. You should also consider LE-607 for your longer change intervals.
watchdogd
Sep 6, 2009 06:36 PM
Millenion LTD
Jul 3, 2008 11:36 AM
tomhawkridge
May 16, 2008 10:48 AM
spectacle
Jun 16, 2006 12:30 PM
knlg
Oct 16, 2005 11:43 AM
