light problem
Old Jan 24, 2005 | 09:43 PM
anthonys2k's Avatar
Default light problem
so anyway...my MY01 driver side signal light doesnt always go on when i turn on the headlights and it is getting really annoying ..i have to get out of the car and give it a bump or knock on it to turn it on...what is causing this...how can i fix it..seems like it can be easy...
Old Jan 25, 2005 | 04:04 AM
xviper's Avatar
Have you considered changing the bulb?
Old Jan 25, 2005 | 07:17 AM
anthonys2k's Avatar
i have, but the bulb lights properly..not dim or anything..just think something is loose...is there a way to get to it without taking the bumper off maybe?
Old Jan 25, 2005 | 05:45 PM
xviper's Avatar
Sounds like you've got a bad harness, bad connection or bad ground. All the rear lights can be accessed from inside the trunk. You have to remove the liner.
Old Jan 25, 2005 | 06:51 PM
anthonys2k's Avatar
cool..i'll check that..but im actually talking about the turn signal in the front by the headlight..is there an easy way to access that?..maybe by the tire?
Old Jan 25, 2005 | 06:57 PM
xviper's Avatar
DOH! Sorry!
To get at the turn signal lights and harnesses, yes, you'll need to undo the wheel well splash shield and go in from there. If you weren't looking for an electrical fault, some owners with small hands can actually change the bulb by going in through the hole in the engine bay.
Old Jan 25, 2005 | 07:42 PM
Slows2k's Avatar
Your title says tailight, which may add to the confusion. I'd change the bulb again while you are there. Usually, you can bump a failing bulb to get the filiment to touch again and light.
Old Jan 26, 2005 | 12:16 AM
anthonys2k's Avatar
i just noticed that!..i didnt realize i put taillight (even though my taillight did it too a while back and i pulled the liner out and fiddled with it and fixed it)...maybe my GF can fit her hand in there to fiddle with it to try and knock it back into place...
SweetWaterSurprise
Mar 21, 2016 08:09 AM
plizzat
Aug 4, 2014 06:45 AM
crispyhihats
Jan 30, 2013 10:08 PM
chrisl113
Apr 9, 2010 12:47 PM
2001_s2000
Jul 9, 2009 10:09 AM
