Location of engine control unit
Old Aug 4, 2001 | 07:05 PM
Walter's Avatar
Default Location of engine control unit
where is and how can I access the ecu so that I may tap into the wires?
Old Aug 5, 2001 | 08:19 AM
Utah S2K's Avatar
ECM is located on the drivers side behind the kick panel.
Utah
Old Aug 5, 2001 | 11:28 AM
DSF_S2k's Avatar
Make sure your warranty is expired. Otherwise, tapping into the ECU will definately VOID your warranty.
Dale
Old Aug 8, 2001 | 06:54 PM
joe_s2k's Avatar
[QUOTE]Originally posted by DSF_S2k
[B]Make sure your warranty is expired.
Old Aug 9, 2001 | 04:47 AM
marcucci's Avatar
Originally posted by joe_s2k
Do you mean connecting into the ECU w/ an OBDII device will void your warranty or splicing into the wiring?
I didn't think an OBD2 device (like a scanner?) was an issue. Hacking the wiring will definitely void your warranty if the shop can prove it.
syclark
Apr 16, 2006 02:34 PM
Hamiy
Aug 17, 2005 12:13 AM
dbox
Mar 26, 2003 10:42 AM
BlueIrishS2k
Aug 30, 2002 06:36 AM
MDS2K
Mar 7, 2001 10:01 AM
