looking for power steering controller
Old Apr 5, 2004 | 03:28 PM
djkojione's Avatar
Default looking for power steering controller
Hello,
I am looking for a power steering controller that contols the EPS levels that the car has. Out of the factory, the EPS adjusts and gets harder to turn, the faster you go. I am looking to control this function, and was wondering if if anyone here knows of a company where they sell this module.
I hear there is a company in europe that has this modification.
thanks all
Old Apr 5, 2004 | 08:02 PM
chris_barry's Avatar
I havent looked closely at this, but would have thought that the EPS would get a speed signal and vary the amount of assistance with speed. More at low speed and less at high speed.
The speed signal the EPS uses comes from an output on the instrument panel. You could try taking the speed input from the gearbox which is at double the pulse rate. ( its an input to the ECU and instrument panel. The instrument cluster halves the pulse rate and sends it to the EPS, headlights and lots of other stuff). This would make the EPS see double the speed and therefore reduce the amount of assistance earlier.
Speedracer.
Old Apr 5, 2004 | 09:00 PM
djkojione's Avatar
interesting.
actually, what i was looking for was to have the power assist on at all times, minus when the car is at a complete stop. cause the power steering adjust uses a motor, i dont want to burn it out when the car is not moving. so....
car stopped - no power steering
anything other than 0mph - full power steering at all times
Old Apr 5, 2004 | 10:36 PM
The power steering only provides assistance when you move the steering wheel. If you leave your hands off the wheel it provides only maintenance assistance.
The standard steering assistance reduces with road speed otherwise you would be zig zagging all over the road at high speed.
Its not as simple as on/off. It provides a variable amount of assistance. I've never seen any posts about burnt out power steering so your concerns about impending burn out may not be warranted.
Speedracer.
Old Apr 6, 2004 | 08:35 AM
djkojione's Avatar
chris_barry - do you have any experience with the EPS control on the s2k? can you tell me exactly how to try to trick the EPS to giving more or giving less "pulse" signal? I am looking for more than just a theory. Any assistance will be helpful.
I am also afraid that if i apply constant voltage to the EPS, the motor will be running at full power, regardless of speed. Basically the power steering will be on full whenever the car is on. I think that in time, the motor will burn out.
Old Apr 6, 2004 | 02:06 PM
Gernby's Avatar
Former Sponsor
I'm not sure, but I don't think the EPS system uses a motor. I think it uses electromagnetic coils.
Old Apr 6, 2004 | 02:14 PM
djkojione's Avatar
the EPS does use a motor. i just found this nifty article about the HONDA EPS systems. check it out, its pretty neat.
http://www.insightcentral.net/encyclopedia/eneps.html
darn, trying to figure this out is harder than it seems...
Old Apr 6, 2004 | 04:10 PM
djkjione,
Put a yellow box speedometer signal corrector on the speed input to the power steering controller. You can then apply a positive of negative multiplier to the speed signal.
I still dont understand your concerns. If you have the standard EPS controller setup there is no known pattern of EPS burn outs. Are you doing something different or bizzare.
Find something else to worry about.
Speedracer.
Old Apr 6, 2004 | 04:14 PM
djkojione's Avatar
chris_barry - ill give that a try! i am doing something very bizzare, there will be lots on this car very soon. this is one of the biggest problems that the car is having, so yup, its something to worry about.
Dklein
Feb 15, 2011 04:29 AM
Ks320
Feb 16, 2009 11:27 AM
JDM Baller
Feb 10, 2008 11:30 PM
Ballistic
Nov 19, 2003 11:18 AM
dohoon
Dec 25, 2002 03:33 PM
