Maintenance Req'd light blinking at start up...what's wrong?
Old Jul 15, 2002 | 04:04 PM
hyperpm's Avatar
Maintenance Req'd light blinks like 5 or 6 times at start up then stops blinking....what could be wrong? Only does this at start up. Is it worth taking it to dealer? Car has 6000 miles on it with recent oil change so not sure what triggered this. Anyone else have or had this problem? Thanks for any info.
Old Jul 15, 2002 | 04:14 PM
DSF_S2k's Avatar
The maint. Req light is programmed to come on every 6000+ miles or so (Oil Change). At first it will blink on start up, and eventually will stay on. You can reset the light, It's in the manual how to reset it, or do a search on resetting the maintenance light.
Dale
Old Jul 15, 2002 | 05:27 PM
boiler's Avatar
This is your reminder to change the oil. Mine comes on at 5250 miles. It seems to be calibrated a bit off.
Bob
Old Jul 15, 2002 | 05:42 PM
JPit's Avatar
If I remember correctly you need to turn off the key and push down on the trip button. Turn the key back on while holding down the button for about 15 seconds. Light should go off.
Old Jul 15, 2002 | 05:49 PM
pfb's Avatar
pfb
The answer to this question, and many, many more can be found by clicking the "Library" link at the top of the page and looking in "Frequently Asked Questions".
If that's too much work, look here: https://www.s2ki.com/article/articleview/5/1/8/
Old Jul 16, 2002 | 05:23 AM
DSF_S2k's Avatar
Actually, the one above is for resetting the ECU. The one you are looking for is here: https://www.s2ki.com/article/articleview/4/1/8/
Dale
Old Jul 16, 2002 | 06:54 AM
pfb's Avatar
pfb
Whoops! Thanks Dale!
Old Jul 17, 2002 | 09:50 AM
hyperpm's Avatar
Wow thanks for the info!
Brian339
Mar 25, 2015 09:21 AM
blobianco
Jan 24, 2011 10:03 AM
03S2
Aug 27, 2010 09:37 AM
SDS2K@9K
Apr 24, 2007 06:05 AM
kilos2k
Jan 21, 2007 09:49 PM
