Map sensor bolts.
Old Jul 2, 2010 | 10:37 AM
chef-j's Avatar
Default Map sensor bolts.
After put new belt/plugs etc and i decided to play with map sensor. And this is what happend...
Passenger side bolt came off really easy but driverside is stuck. I tried center punch and small grip wrench but couldn't remove that one bolt. ( Now it stripped more than that picture) I will play with this again when i have time next week.
BUT what i notice it is, those two bolts are VERY WEAK.
BTW Anyone know bolt size? was it 4x16?
Thanks.
Old Jul 3, 2010 | 07:09 AM
jeggy's Avatar
trick i have learned. take a small hacksaw and put a cut in the head effectively turning the phillips head into a standard flat blade type. this will now allow you to use a flathead screwdriver.
seansniper
Jun 20, 2012 08:35 AM
s2kseven
May 21, 2012 10:19 AM
ayashifx55
Mar 17, 2011 07:47 AM
chorne1787
Jun 25, 2009 06:58 PM
s2kbtos
Apr 9, 2009 02:51 AM
