Mechanical O2 Simulator
Old Aug 21, 2005 | 08:50 AM
  #171
ajaydm's Avatar
Ill give it a look again it was dark
thanks
Old Aug 21, 2005 | 07:41 PM
  #172
ajaydm's Avatar
I got it on, but mine is also pionting downwards at a bad angle
i have 1 t1r also
Old Aug 25, 2005 | 03:20 PM
  #173
TougeBomber's Avatar
Originally Posted by Silver9k,Aug 21 2004, 11:06 AM
I have the 42009, are the only differences between these two the length and the 42009 having washers?
Is one better than the other?
Thanks
Philip
Old Aug 25, 2005 | 03:49 PM
  #174
xviper's Avatar
I don't think the shorter ones with the washers will fully house the O2 sensor. The longer ones (top photo) has bevelled ridge just beyond the threads. This is why they don't need washers. The longer ones will protect the sensor better. Not sure if this is important but I used the longer ones.
Old Aug 25, 2005 | 10:03 PM
  #175
demonderrick's Avatar
anyone knows if it will work with SC setup????
Old Aug 26, 2005 | 07:49 AM
  #176
xviper's Avatar
Yes, I have it on mine (Vortech).
Old Aug 26, 2005 | 09:39 PM
  #177
I just installed my test pipe with the shorter ones without using the washers and luckily I got no CEL and no clearance problems...
Thanks for the comment though...
Since the intall was kinda sudden I didn't even use a drill to make the hole bigger me and some friend took turns borring it out with a screwdriver!
It still works and the O2 sensor isn't harmed and it's all good...
Old Aug 26, 2005 | 10:10 PM
  #178
xviper's Avatar
That would have been something to see. Having done it on a drill press, I just can't imagine how you could do it that way. You must have a magic screwdriver.
Old Aug 26, 2005 | 11:35 PM
  #179
Silver9k's Avatar
Seriously, I hope that screwdriver was Craftsman so you could take it back now and exchange it, it must be mutilated
Old Aug 27, 2005 | 01:51 AM
  #180
It took a whyle, luckily we were smoking a hooka and working on another car to pass time...
Also the screwdriver didn't look bad afterwards, since it's sorta tappered there wouold be a different part of the screwdriver doing the cutting as the hole got bigger...
Rigged as hell but it did the trick at the last moment...
