Mis-shifted from 3rd to 2nd at WOT; looking for advice
Originally Posted by lqh2552' timestamp='1429795479' post='23588373
[quote name='bgoetz' timestamp='1429785100' post='23588252']
IDK if there is a need for a whole new head. The head has to come off either way so why not check to see if there is any valve seat damage, if not just replace the valves and retainers with AP2?
If you damaged the valve seats then yes a whole new head is best.
You're not the only one who had made this mistake haha. I myself did the exact 2nd gear mis shift a month ago but luckily i had updated ap2 seats and retainers so i didn't drop a valve, just bent one. After the incident I took my head off and it was still in great condition so I decided to go with a new valvetrain from Ferrea to prevent any future headaches. It happens, man. The thing to take away from it is now you can build it stronger!
[/quote]
Haha, good to hear. I actually just want to keep it stock, to be honest. If it can get back to its original form, I'd be more than happy at this point. It's so weird, though, the third to fourth shift should be the easiest shift as the shift is straight down the middle. Well, I guess I gotta start learning to shift this car with lighter pressure and not force it.
BTW, my S2000 is also a 2002 Sebring Silver with a red interior! At first, I thought it was pretty awesome, but now I kinda wish the interior was black. For some reason, the material on the door panels is fading much faster than the dash material. And it's pretty obvious too, haha.
Don't attempt to start the engine anymore. Take the head off the block. The head needs to be inspected. If the cylinder sleeve didn't crack then you will just have to work on the head. Check engine rotation while head is off and inspect the walls. You said there is oil on the Pistons, not a good sign. Search on this website for a low mileage motor and keep the other parts for possible spares
I have started looking for a used motor in case of the worst case. And that is a good idea to harvest the second motor for future replacement parts as I plan to keep this car indefinitely.
SomethingWicked
Oct 15, 2002 11:54 AM
