Misaligned Cam Gear
Misaligned Cam Gear
First, I tried to search for something fitting this but wasn't able to find it. If I just fail I apologize.
As far as I can tell from a before picture the exhaust cam was aligned when I took it off to replace the retainers and keepers. At some point it seems to have shifted between the back small section and the larger front section. Is this something that can be adjusted? If so what do I need to take apart. Here is the after pic:
I got around to taking apart the gear and it looks like one of the pins that align the two sections of the gear is slightly bent so they will no longer align. Not sure if it could be bent back but I think I'm just going to replace the gear.
