More broken retainers, 6TH TIME
The intakes are the only ones I replace. The exhaust retainers don't split, because the valves will hit the piston first. Also, the exhaust valves don't float at the same RPM as the intake because of their weight.
IMO:
The retainer splitting over-rev RPM is raised with the 2.2 retainers. Possibly beyond the point in which the exhaust valves bend.
IMO:
I assume the Honda engineers have certain design guidelines they follow, and those guidelines just didn't allow for any more mass in a 9K engine than they used for the AP1 retainers. When they lowered the redline, they beefed up some things because they could.
Billman...
So when you replace retainers, are you using the compressed air method to do it? And when you are using the compressed air, do you have that piston at TDC or BDC...
And do you have the part numbers for the stuff one would need for replacing retainers?
And do you also have the part number for the oil squirters off hand? I had it written down somewhere, and cant find that paper now.
Originally Posted by Billman250,Apr 23 2007, 06:01 PM
Piston at BTC. At TDC, the air will push it down to BDC anyway.
