More broken retainers, 6TH TIME
Old Apr 23, 2007 | 11:01 PM
  #41
mikegarrison's Avatar
Originally Posted by jeggy,Apr 23 2007, 05:34 PM
i did notice the lines that circled the retainers but brushed it off as something else since all the photos of cracked retainers were vertical.
Go back to this picture:
There is a line that runs all the way around the retainer right at the base of the conical part (where it's almost flat, just before it does the vertical step that actual seats the spring in place). This is not the crack -- it's normal.
There is also a (jagged) line running around the middle of the cone, right above where the flash reflection is all white. This is the crack, and it very much is not normal.
Old Apr 24, 2007 | 04:35 AM
  #42
SpitfireS's Avatar
FWIW
FYI
I've called my Honda dealer and asked if this part# was available:
14765-PRB-A01 (F22 retainer)
Their computers look into the parts database for Germany & the Netherlands & Belgium (maybe even Luxemburg)
Reply: yes, its a retainer for the Civic Type-R MY07.
It would be informative to find out how much force it takes to make a cracked retainer fail.
The visible cracks in the pictures Billman posted make me think the cracked retainers are up to 50% damaged and still they don't fail as soon as the damage was done, IOW there is some safety margin.
In a way thats kinda reassuring.
Old Apr 24, 2007 | 06:56 AM
  #43
aero3685's Avatar
Originally Posted by SpitfireS,Apr 24 2007, 04:35 AM
FWIW
FYI
So the new retainers are the same as used for MY07 CTR's...
Billman, is the part number 14765-PRB-A01 (F22 retainer) the same one you use?
Old Apr 24, 2007 | 02:11 PM
  #44
JeffForSale!'s Avatar
what constitutes an overrev? isnt there a rev limiter to prevent this?
Old Apr 24, 2007 | 02:16 PM
  #45
Spec_Ops2087's Avatar
The rev limiter can't stop you from putting your car into second gear doing 100mph.
Old Apr 24, 2007 | 02:17 PM
  #46
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Wrong gear over rev. Not hitting the rev limiter.
It is over-reved mechanically by the rear wheels, rev limiter can not stop this.
2.2 retainer 14765-PRB-A01
2.2 keeper 14781-PCX-004
Old Apr 24, 2007 | 04:01 PM
  #47
jyeung528's Avatar
billman,
wouldn't you suspect further damage...than just the retainers?
such as valves, valve guides?
Old Apr 24, 2007 | 04:36 PM
  #48
Otherguy's Avatar
just got done looking at mine, everything checked out
Old Apr 24, 2007 | 05:17 PM
  #49
jeggy's Avatar
Originally Posted by Billman250,Apr 23 2007, 05:02 PM
I call BS on 16 craked retainers.
i wont take offence to this because i belive you are a very respectable person and doubt that you are trying to insult me in any way but rather just doubtfull in what im saying.
if you would supply me with a shipping address i would gladly send you the 14 (i took 2 to my workplace to show a coworker) overreved retainers i replaced from my engine. and if you still dont belive that all these retainers came from a single engine, then at least we have 3 cases of these cercumfriential(sp) failed retainers.
Old Apr 24, 2007 | 06:40 PM
  #50
Mr. Eryozgatliyan's Avatar
Banned
Originally Posted by Billman250,Apr 23 2007, 03:11 PM
How come the top of the springs turn yellow like that?
