Mystery "Clunk" in Front End
Old Feb 11, 2015 | 06:37 AM
Topplayer's Avatar
^for that to happen you really really have to abuse the car, no DD will ever have them problem from normal driving. I have countless hours on my track car and never had a issue on my ap1 lol very few have ever reported this issue so I doubt he has it
Old Feb 11, 2015 | 08:04 AM
Gregg Lee's Avatar
intermittent mystery noises can be difficult. Try
branch stuck under the car
loose body work "flap" in front of tire (if the 2006 still had them)
loose under-tray
loose fender liner
loose anything bolted to the side sheet metal in the engine compartment
sway bar bushings
sway bar end links
steering tie rod end
lower ball joint
upper strut mount
all other suspension bushings
Old Feb 11, 2015 | 08:19 AM
Gregg Lee's Avatar
Originally Posted by scottdh20
check the upper a-arm braket mount on the chassis.... they have been known to go bad (spotwelds rip out) with lots of racing/use of r-compound tires....although it typically effects ap1 over ap2 it could be a place to checkout.
This is real. I had this happen, but it never made noise. But some reported a popping noise associated with it. Eventually mine got loose enough for the car to start steering itself as the suspension shifted. Undercoating tends to hide it in early stages.
However I wouldn't look there first unless your car has some specific history. As far as I know the only cause is repeated hard braking when using high grip competition tires. Autocross competition, where multiple maximum braking events occur in every run is where this was first reported. (Until recently, soft compound, nearly treadless, not recommended for street use tires were legal in autocross "Stock" categories.) This is a metal fatigue failure that requires many many repetitions under high load, a load that may not even be achievable with road tires.
ISADE
May 17, 2018 06:53 PM
Fatbloke
Sep 20, 2009 07:12 AM
phiesope
May 18, 2009 09:39 AM
soozookabluS2k
Mar 14, 2009 10:36 PM
ECale3
Nov 21, 2008 02:50 PM
