Need help...
Old May 25, 2006 | 07:25 AM
CIVICTOS2000's Avatar
Default Need help...
Hey I was wondering how could I tell if I needed new oil seals of my diff ?
part # 32
Thanks a lot...
D.
Old May 25, 2006 | 07:32 AM
Wisconsin S2k's Avatar
you'd see fluid leaking out of the seal. enough that it's a continuous leak.
Old May 25, 2006 | 07:37 AM
xviper's Avatar
Am I not understanding the question or is there some other meaning behind it? I mean, you either see a leak or you don't.
Old May 25, 2006 | 12:58 PM
I saw a leak after I got the new gears in... they look ok.. I had to remove the differential again, I looked at them and like I said they seem to be fine...but I don't really know about rubber seals...so I was wondering if there was a way of telling, like cracks or something....or If I'm supposed to do something when installing the inner axles into the diff.... Thanks a lot..
D.
Old May 25, 2006 | 01:04 PM
robin2race's Avatar
why don't you take the seal out and look for cracks or damages?
Old May 25, 2006 | 01:15 PM
well I guess I can do that I just wasn't sure if they were reusable once you get them off...Sorry I'm just paranoid now...
D.
Old May 25, 2006 | 01:45 PM
robin2race's Avatar
yeah, i understand and it's not a bad thing to be paranoid when it comes to a car stuff, but just not too paranoid, though.
well, just be careful not to damage the seal when taking it out.
And for additional information, sometimes the fluid leaks out of the seal if the vent hole on the case is plugged by dirt or some sort.
I don't know if that's the case this time, but it wouldn't hurt it to check it, I would say.
Good luck!
Old May 25, 2006 | 01:49 PM
most often, when you remove the seal, it should be replaced.
and you don't need to take the seal out to see if it's bad. if it's leaking diff fluid, then replace it. if not, then don't. it's that simple. me and xviper have conveyed this to you, however, is there some confusion as you don't seem to have responded to our posts.
Old May 25, 2006 | 01:56 PM
xviper's Avatar
Those seals needed to be treated very carefully when doing the gears. The slightest nick and they will leak or if dirt got onto them. When doing gears, you need to protect them with heavy grease while you are working on the gears. If you take them out, you merely replace them. You can't really "inspect" seals. Just change them.
Old May 26, 2006 | 05:26 AM
I'll do that Thanks...
F22C1-215
Sep 5, 2013 08:48 AM
Danfotoman
May 28, 2012 05:25 AM
CIVICTOS2000
Jun 9, 2006 09:03 AM
CIVICTOS2000
Mar 24, 2006 12:51 PM
swtazn97
Apr 19, 2004 04:10 PM
