Need Help! Car misfires on start up on throws CEL
Old Jul 15, 2011 | 10:26 PM
YakuzaSiR's Avatar
Default Need Help! Car misfires on start up on throws CEL
Hey All
My car has been throwing a CEL for a bit and its due to a misfire in three cylinders. This is most evident on a cold start but can be heard sometimes while driving at regular speeds. Went about changing the plugs and battery (battery was on its last leg) thinking it was something minor but to no avail. Any additional signs I should be looking for to diagnose the issue? I am playing with the idea of new ignition coils thinking mine could have gone out but was also considering the timing belt as a source of the problem. Car is a MY05 with about 70k on the clock. Spoon N1 exhaust and test pipe with PRM intake. Nothing crazy done on the motor, regular tune ups and no tracking. Any advice would be greatly appreciated!
Old Jul 16, 2011 | 02:09 AM
SgtB's Avatar
It's not the timing chain.
Old Jul 16, 2011 | 09:34 AM
whippets2k's Avatar
What are the codes exactly?
Have you checked this out yet? https://www.s2ki.com/s2000/topic/659930-misfire-thread/
Old Jul 16, 2011 | 10:50 AM
s2klariat's Avatar
Originally Posted by YakuzaSiR
Hey All
S2000's have a timing chain, not belt. The chain wouldn't cause a misfire anyway. First of all have the codes pulled and list them. If you are having misfire issues there are a few things you should check. Compression and leakdown test, check valve clearances and adjust as needed, confirm spark from each coil, and in some instances your injectors may need to be flow tested, but I wouldn't count on that one.
Old Jul 18, 2011 | 07:23 PM
YakuzaSiR's Avatar
Awesome thanks for the help guys. I'll try troubleshooting a little more using the stuff from the thread and let you know whats up. Also, the codes were 1 2 and 4 cylinders misfiring.
turtleesss
Oct 6, 2019 12:59 PM
mat_turbo
Oct 15, 2014 07:12 AM
djweaver
May 26, 2010 02:15 AM
ericb25
Nov 4, 2009 07:03 PM
Amer
Feb 22, 2006 05:37 PM
