Need Help Please!!!!!!!!!!!!
Old Dec 23, 2002 | 05:24 PM
BlueS2000Boy's Avatar
Default Need Help Please!!!!!!!!!!!!
i am painting my calipers as we speak i got the two front done and i got all 5 lugs off one of the rears and i got three off the other. two lugs will not move at all. i have an impact wrench and they still won't come off. i tried by hand also. if there any other way i can loosen these things please help.
Old Dec 23, 2002 | 06:01 PM
xviper's Avatar
Have you tried just a regular socket with a non-rachetting handle and a long pipe on the handle? Car on the ground, wheels chocked.
If they are on that tight you risk breaking the studs, so what have you got to lose? Reverse the impact wrench and run it for a few seconds (ie. drive them tighter). Then try to remove them again. Repeat if necessary.
How'd they get that tight?
Old Dec 23, 2002 | 07:11 PM
well thankfully they came off. i just used the oem wrench. it worked but with a lot of force. i just had new rear tires put on and the people who did them said they tourqed them to the right specs but i guess not. it was kinda weird cause all the other ones came of with no problem but just these two would no move. what would making them tighter and then loosing them again do? thanks for the quick reply
Old Dec 23, 2002 | 07:27 PM
xviper's Avatar
It's an old mechanics trick. If all else fails and the nut or bolt is on too tight due to rust or corrosion, banging them tighter will usually (but not always) break the bond that's holding it on.
Old Dec 23, 2002 | 07:29 PM
xviper's Avatar
Oh, and ps.
If the shop doesn't use a torque wrench (which they should be doing) and use an impact wrench instead, they should be using a "torque stick" attachment. Next time, insist on it beforehand.
Old Dec 23, 2002 | 11:46 PM
Schatten's Avatar
xviper - regarding the torque stick - its a great tool, or rather was when it came out. Discount Tire implimented it in all of their shops for the longest time. However, they have since gone back to the torque wrenches in the past few years because of the lifespan of the sticks. Apparently after a period of time in using them, they aren't within range.
Old Dec 24, 2002 | 08:21 AM
xviper's Avatar
Schatten, good point. A torque wrench is always my first and preferred choice.
Old Dec 24, 2002 | 08:42 AM
The Unabageler's Avatar
i just put my lugs on finger tight. They snug up as I drive.
Old Dec 24, 2002 | 09:13 AM
xviper's Avatar
[QUOTE]Originally posted by The Unabageler
[B]i just put my lugs on finger tight.
Old Dec 26, 2002 | 09:49 AM
payneinthe's Avatar
[QUOTE]Originally posted by xviper
[B]
s2000maniac
May 3, 2011 05:09 AM
xdavieexx
May 1, 2008 11:17 PM
tinkfist
Apr 17, 2006 08:11 AM
Hondo
Mar 15, 2004 10:20 PM
Busch
Jun 19, 2003 08:11 AM
